OldmanRick
Problem solved.....If your running sliders with nothing more then a snubber that's it. There's no control of the housing at all. Remove the sliding perches and get a reasonable cost pair of adjustable shocks.
Sliding perches isolate the housing from the support, in this case the leaf springs. Ladders and 4-links let the springs work, along with the sliders, without changing the pinion angle drastically by controling housing movement. At this point i think you have to decide one way or the other. Leafs and no sliders or sliders and housing control. I agree that the times you are running by no means restrict you from going back to a regulation mopar set up.
