fredsmedina
6 Dart 7 MOPAR OR NOCAR
i need to completely rebuild my front end on my 67 dart. i have no clue what i'm doing, but i wanted to know if anyone has some tips or advice for me? thanks in advance!
When you are ready to do it, keep in mind Redfish's suggestion in post #5.
I think I can answer this one for Redfish. The 67 K member only has one support for the idler arm whereas the 68 K member has two. To use the 68 idler you`d have to weld an upper support on to the K member. The modification could be cost effective because a 67 idler arm is way expensive (over 100 dollars) while the 68 idler is a fraction of the cost.
makes sense. thanks for that info. i was planning on buying an entire front end kit though to do the rebuild. would you guys here on FABO recommend buying a complete kit or would it be better probably to piece together my own. because by piecing my own together, i would be able to get this 68 idler arm.
You can save a lot of money buying everything in a kit. The only reason for buying things seperately would be if you were using some custom parts like C-body tie rod ends or offset upper control arm bushings. All of the parts for your 67 should be the same as the 68 except for the idler arm. So if you planned on changing to the 68 arm you could simply order a kit for a 68. PST is a sponsor of the site here, you can click on their site and see what they have to offer. I`ve used them for 3 cars so far and their prices are very competitive.
I got a complete rebuild kit from Just Suspensions last summer. contained all bushings, ball joints, tie rod ends, etc. Also got their "Six Pack of tools", it was an extra $200 but since we'll be doing other cars it was worth it. One of the tools negated the need to take the upper control arms/bushings to a shop to get them pressed out/in. Also came with a ball joint socket that you stuck on the end of a breaker bar, and could just pop the ball joints out. I didn't have to use a pickle bar or anything like that. All the tools in the kit took care of everything. It was great. I was able to do everything in my driveway on a Saturday, took the full day, but it was well worth it.
Oh, and I had no clue what I was doing before hand, just had read the service manual, and talked to a friend who had done it and said it was a major pain in the butt...it wasn't.
Just went to PST and the price of a rebuild kit is $219 for either a 67 or a 68 ... indeed for a 57 - 89.
Here's the contents:
MOST KITS CONTAIN:
* 2 Upper Ball Joints
* 2 Lower Ball Joints
* 4 Upper Inner Control Arm Bushings
* 2 or 4 Lower Inner Control Arm Bushings
* 2 Strut Rod Bushings ( if required)
* 2 Outer Tie Rod Ends
* 2 Stabilizer Links (Bolt and sleeve type links only)
* 2 Sway Bar Bushings (for most models)
* Control Arm Bumpers (for most models)
The super kit (with more stuff, incl idler arm) is $379 for any year but 67 and $399 for the 67 ... not much diff.
If the idler arm separately bought is 67: $94 vs 68: $39. So I'd question the advisability of welding onto the K just to save either $20 or $55.
That`s a good buy on the kit. I wouldn`t go to the trouble of modifying the K-member for such a small difference in price either.
