Factory type seals are too wide for the dual springs modern cams need. The seal wont fit in the spring. So you have to cut the guide smaller in diameter. The stock retainer will hit somewhere around .520 or so depending on the engine so at the same time you make the guide shorter. Also, the spring won't fit in the spring seat on the head. You have to cut the spring seats for the inner spring too.
