Mopar to ya
I have Comp Cams roller rockers and hydraulic roller lifters. I had a ticking noise that I was able to make go away by finger tightening one of the adjusting ball studs. If that was loose, I had better check them all. Do you do the same 90 degree adjusting as Mopar OE style, and the same order? I would assume not. Also, I don't know how much lash. Anyone know specs and order and procedure?
