How to? Fix a sagging fiberglass hood... Heat Resistant Foam?
Hemioutlaw
Make America Great Again!
The Great State of Texas
Hey y'all,
Lotta life happened and been gone for a bit but i'm back and with a vengence.
Help needed for this sagging fiberglass hood on my 64' Valiant, as you can possibly/hopefully see in the images it's sagging in the center on the sides. As a first thought I had some foam from an old Moroso airpan that I laid under the hood and it propped it up perfectly so I was thinking that I could just use some weatherstrip adhesive and attach it to the bottom of the hood. Problem is that this foam was probably 15 years old and falling apart. If I go this direction I'm wanting to buy some more foam that is both Heat Resistant and has good rebound characteristics 1 1/2" x 2" is ideal but damned if I can find anywhere on the web to buy some?
Thought number two was adding some dzus, it's currently secured by four pins but the entire front end is also fiberglass so i'm a bit reluctant to add dzus fasteners.
Any ideas
Hey y'all,
Any ideasView attachment 1715418299 View attachment 1715418300 View attachment 1715418301
you could add a couple of stock type hood bumpers on the sides, a couple of more hood pins (which u need anyway) , and turn it upside down an glass some cardboard stiffeners in it to hold the contour you want. Cardboard is used on almost all fiberglass hoods that I`ve seen.
Hose done neatly and cut to the right length slid over ur hood pins will hold the hood at the height u want to match the fenders.
Thx FB,
Some good idea's there that will definitely provide a more effective long term solution,I did have foam on the pins (already compressed) and why i hadn't thought of something as simple as hose.....wellllll!
Having never worked with glass before I guess I better find a good UTube vid and figure a way to get the contour i'm wanting to replicate while the hoods upside down being glassed and curing..would shaped wood clamped to the curing hood be what i'm looking for?
Thx FB,
??? Unless its really flimsy , it might stay the right shape with simple blocking and spaceing , upside down on a couple of sawhorses .??
Go online and look for fiberglass supplies.
Quality glass will use a honeycomb material instead of cardboard and you can buy it in various thicknesses and widths. Or you can cut to whatever size or shape you need.
Man I'm brain dead....never thought to ask my son...he builds fiberglass hoods for military vehicles.
We talked about that stuffs few months back. I'll have to ask him again.
We fixed a fiberglass challenger hood by fiberglassing some 1 inch wood stripes into the bottom on each side of the scoop.
