How to identify OEM vs aftermarket heater core?
rftroy
Active Member
68 Barracuda, non-AC.
How do you identify an OEM heater core? I have 2 as rebuilding candidates.
I don't see any Chrysler markings, which I would expect with an OEM core.
Robert
Post some photos.
My recollection they have a honeycomb pattern.
I believe this is an OEM 67 core
There will be no factory markings. Original cores are copper while some aftermarkets are aluminum. I would never "rebuild" one as they are too delicate. No choice of material when replacing, just be happy that you can get one at all.
If you have a air supply, even a bicycle pump, and a way to seal the ends to keep it under pressure (16 to 20 lbs) and a gauge on it over night. if it looses pressure bad, if not good. also submerge it in a tub of water look for bubbles. I like the hot water circulating through it some expansion could cause a leak BUT I suspect an overnight leakage test would show that up too. ( just be sure its not leaking at the ends where you have the plugs etc.)
Heater cores can be rebuilt, we have one shop left here, he did mine. It did cost more than a cheap replacement, there do seem to be different levels of quality core materials.
can vacuum test too ....
My only problem with vacuume on normally pressurized systems is the possibility of sealing a leak shut with vacuume.
I have never used vacuume so I don't have real world experience
Yeah it's just easier for me
Have a vacuum pump and a plug
It's hard to regulate 20 psi
And any more and she could blow
