Hurst 3836 64-67 A-Body Shifter
Have you tried the hurst shifter doctor he rebuilds shifters and rod sets real nice guy to deal with
Google hurst shifter doctor
I usually buy parts from him when I rebuild a Hurst shifter, but this is a really early kit. Most Mopar A body Hurst stuff if not available. I'm not really interested in the generic Hurst shifters and new kits. Thanks.
A few more questions on this 3836 shifter:
1) Is there a rebuild kit that is close to what is needed?
My understanding is there is not a complete kit.
2)My plan is to use a 3836 shifter on a cast OD trans.
I bought the parts below from Brewers, the first is the a-body OD linkage rod (no # cast into it), the second is the OD lever set, 064, 065, 875.
Will these new parts work with my existing 3836 shifter with the 1/2 and 3/4 rods it came with?
A/F-BODY 3-OD SHIFTER LINKAGE ROD/SWIVEL - Mopar A833 4-Speed Transmission & Component Specialists
1976-UP DODGE TRUCK OVERDRIVE SHIFTER LINKAGE OPERATING LEVER SET - Mopar A833 4-Speed Transmission & Component Specialists
I realize the OD lever set is listed as 'truck' however it is the same set that comes with the full cast OD a-body shifter kit:
1963-1976 A-BODY NEW SHIFTER PACKAGE -CAST IRON OVERDRIVE TRANSMISSION - Mopar A833 4-Speed Transmission & Component Specialists
3) Below are pics of my 3836 a-body shifter next to my b-body shifter.
These look identical, same numbers in the case, levers appear to be exact.
Are these interchangeable?
