I CAN’T DRIVE 145mph
Mopar Performance Issues
  1. loganscuda
    loganscuda DON’T reMember
    2,541
    2696
    Jul 15, 2010
    san antonio
    Local Time:
    9:03 PM
    Stock 5.7 Hemi with 545rfe trans. 373 gears and can not go faster than 130mph now. What do I need to do to get up to 145mph.
    Plan on doing an open road race in West Texas at Big Bend National park.
    It is 118 miles round trip and want to run the limit for my cars specs. What to do?
    FYI I do have Alterkation front and Firm Feel Leafs w Bilsteins. Handles very good now. Will add spoiler to front.
    I did not check my rpms when I was at top speed. I did have overdrive on. Do not know if that makes a difference. Looking for the simplest way of doing it.
  2. roccodart440
    roccodart440 Well-Known Member
    5,767
    4758
    Apr 19, 2010
    Local Time:
    10:03 PM
    If you weren't at redline it's a power issue.
    I mean aerodynamics obviously hold you back but our cars are flying bricks so refer back to my first line.
  3. loganscuda
    2,541
    2696
    Jul 15, 2010
    san antonio
    Local Time:
    9:03 PM
    That’s what I figured I wasn’t sure if I changed from a 373 to a different gear it would help
  4. Treblig
    Treblig Well-Known Member
    7,209
    4649
    Oct 5, 2013
    South Texas
    Local Time:
    9:03 PM
    "What do I need to do to get up to 145mph."
    Really good tires????:steering:
    • Like Like x 3
    • fishmens67
      fishmens67 Well-Known Member
      10,471
      9158
      Nov 10, 2012
      idaho
      Local Time:
      9:03 PM
      are you driving the fastback in your avatar at speeds of a buck 45 on the highway ?
      If so, you are cheating death. imo in my experience driving my 67 fastback, at about 110 mph with a little wind she begins to float, a little spooky on the frontend.
    • loganscuda
      2,541
      2696
      Jul 15, 2010
      san antonio
      Local Time:
      9:03 PM
      Yes the fastback but not on Highway My brains are a little bigger than that. On a formula1 track. Circuit of the Americas
      • Like Like x 4
      • autoxcuda
        autoxcuda Well-Known Member
        7,261
        1506
        Apr 6, 2007
        Local Time:
        7:03 PM
        Does the stock Hemi computer have some sort of speed limiter?
        Is there some real long special straight area at Circuit of America for speed trials?
        I’d think there might not be a section of track on the road course to get up to 145 until you’d have to brake.
        • Like Like x 1
        • Thanks! Thanks! x 1
        • loganscuda
          2,541
          2696
          Jul 15, 2010
          san antonio
          Local Time:
          9:03 PM
          Yes there are 2 straights. Maybe there is a limiter on there I have not done a custom tune only have a Diablo tune on it. Did not think of that being the problem. Will have to find some place to go to test. The COTO track is too expensive for me I got lucky and got in after someone dropped out of a group rental.
        • loganscuda
          2,541
          2696
          Jul 15, 2010
          san antonio
          Local Time:
          9:03 PM
          Love your car by the way. You have helped me out tremendously over the years.
          • Like Like x 2
          • Agree Agree x 1
          • mbaird
            mbaird mbaird
            7,232
            4017
            Dec 10, 2005
            boise, Id
            Local Time:
            8:03 PM
            Are aerodynamics different on the track vs the highway?
          • loganscuda
            2,541
            2696
            Jul 15, 2010
            san antonio
            Local Time:
            9:03 PM
            Only if your smoking and the window is Down on the highway.
            • Like Like x 1
            • Treblig
              7,209
              4649
              Oct 5, 2013
              South Texas
              Local Time:
              9:03 PM
              Depends on whether you're going sideways or not!!!:lol:
              • Like Like x 3
              • brian6pac
                brian6pac Well-Known Member
                5,418
                3814
                Nov 15, 2016
                N.E.Ohio
                Local Time:
                10:03 PM
                Put it up on some good jack stands and start running through the gears and see what speed & rpm you are running, no wind resistance!
              • loganscuda
                2,541
                2696
                Jul 15, 2010
                san antonio
                Local Time:
                9:03 PM
                Aaah I remember now, About 6 years ago I put in on a Dyno at MATS Las Vegas and it topped out at 155 and it would not hold at 5500 rpms it would drop back down the speed would stay but the rpms would not go up past that.
                I had 323 gears and I had the overdrive on, I did not have the switch hooked up to turn it off.
              • TrailBeast
                TrailBeast AKA Mopars4us on Youtube
                21,716
                9554
                Mar 11, 2011
                Arizona
                Local Time:
                7:03 PM
                Keep it out of OD and let the engine run to it's highest HP producing RPM's.
                AND make sure you have tires that are up to it, like mentioned.
                • loganscuda
                  2,541
                  2696
                  Jul 15, 2010
                  san antonio
                  Local Time:
                  9:03 PM
                  Tires are good. Goodyear eagle F1. Thanks.
                • Pascamp
                  Pascamp Well-Known Member
                  854
                  731
                  Feb 27, 2016
                  USA
                  Local Time:
                  10:03 PM
                  Don't know your tire size, hp, or rpm, but might be aero/hp related. My 392 Challenger will comfortably cruise at 160. That's with the 6spd manual, 3.90 gears, and stock size tires. Truthfully it doesn't feel like it's trying very hard. The suspension and steering is a different story though.
                  • Like Like x 1
                  • DFX 340 Duster
                    DFX 340 Duster FABO Gold Member FABO Gold Member
                    1,841
                    706
                    May 14, 2009
                    Orange County CA
                    Local Time:
                    7:03 PM
                    As previously stated, the cars of the 60s and 70s ares blunt nosed boxes trying to move through the air. Cleaning up the aerodynamic inefficiencies as much as possible is recommended to increase the power band (mph) and gain better fuel economy. These were some of the tips that were published back in the 1970s when we had the gas crisis: front chin spoiler or splitter molded in, a direct connection style spoiler on the deck lid, have a bottom engine compartment cover made to smooth out the air flow under the car (eliminates or reduces turbulence in the engine compartment), and a solid sheet metal/plastic dam behind the grill with indirect air flow through the radiator.
                    • loganscuda
                      2,541
                      2696
                      Jul 15, 2010
                      san antonio
                      Local Time:
                      9:03 PM
                      0B32F91E-88CA-43A9-9265-05318CA6A91A.jpeg Soooo I need to do this!
                      • Like Like x 8
                      • DFX 340 Duster
                        1,841
                        706
                        May 14, 2009
                        Orange County CA
                        Local Time:
                        7:03 PM
                        • Like Like x 1
                        • 65 Dartman
                          65 Dartman FABO Gold Member FABO Gold Member
                          12,409
                          3799
                          Sep 24, 2006
                          Strasburg, VA
                          Local Time:
                          10:03 PM
                          • Like Like x 1
                          • Agree Agree x 1
                          • Fisher
                            Fisher Old Guy with a Cool car.
                            1,950
                            924
                            Jul 22, 2012
                            Regina Sask Canada
                            Local Time:
                            9:03 PM
                            How tall of a tire do you have? A 26" tire with 3.73 gears will go 145 mph at 7000 rpm. so if you have enough motor to make power to 7000 rpm you are good to go.
                          • Fisher
                            1,950
                            924
                            Jul 22, 2012
                            Regina Sask Canada
                            Local Time:
                            9:03 PM
                            A 27" tire will do it at 6750 rpm.
                          • adriver
                            adriver Blazing Apostle
                            8,950
                            5746
                            Jun 1, 2007
                            Where the red fern grows
                            Local Time:
                            10:03 PM
                            Some of that wind noise you hear is your drip rails.
                            Notice the lack of expose drip rails new cars?
                            And you have all that stuff hanging under the car.
                            The Super Cuda looses some trim.
                            • Like Like x 1
                            • 66fyssh
                              66fyssh Don't Stop Believin' FABO Gold Member
                              6,358
                              5909
                              Jun 22, 2013
                              Northwest GA
                              Local Time:
                              10:03 PM
                              I just looked through your photo garage. KILLER car!! :thumbsup:
                              • Agree Agree x 1
