UBNOXS1
Member
So I was just given my brothers old Plymouth Duster 1970 I have to change the head gasket but I not having much luck with the head its not moving I got part of it to come up. Do anyone know any tips tricks to get it off.
If you have all the bolts out..take a 1/2 inch break bar..put it part way into one of the intake ports..and pull back.......
How -- many -- head -- bolts -- did -- you -- remove -- ?
Hello everyone thanks Yea there was a bolt I missed dose anyone know about what would be the cost get the heads to get redone and what I should be asking for?
old engine just get them surfaced put it back together. drive it and build a good engine in the meantime is my advisePrice will vary depending on what needs to be done to them.
x2 water will run out when it breaks freeIf you have all the bolts out..take a 1/2 inch break bar..put it part way into one of the intake ports..and pull back.......
AND how much of it did you get to move and how far you mit have to check more than the head??just a thut,,,,ArtieSo I was just given my brothers old Plymouth Duster 1970 I have to change the head gasket but I not having much luck with the head its not moving I got part of it to come up. Do anyone know any tips tricks to get it off.![]()
