I hate this new crap. Typical 44/46?" inch flat, and NO decent outputs. No speaker/ headphone jacks, no analog audio. Only "out" is this stupid optical digital audio. And I could not get it to work right with the adapter. You have to go into the menu and fiddle with some delay setting to sync the audio / video and for some reason it would not stay put channel to channel. Also the digi output is line level, so the remote speakers are no longer controlled by the remote
Big issue, is that often, watching a movie on DVD or from the ROKU box via HDMI there is not enough audio for some reason. "Off the air" TV is "just enough" usually, but an external input is not
So tonight I pulled the back off, mounted two china RCA jacks in the back, and paralleled the jacks with the damn poor little tiny speakers. I may hook them to an amp but I'll have to use some form of isolation as the speakers are not at common ground. But just hooking them to a mediocre pair of larger speakers---closer to "me" may be all the difference I need
...........And the screen was dirty LOLOL
