Pretty safe bet that every car ever made came with factory air when it rolled off the assembly line.
Heres one for you...way back in the day.
Some of you may not know that at an auto assembly plant, tires were filled with air around the bead as doing that through the valvestem would take WAY too long! And the hole in the wheel for the valvestem came in punched out - but quality control being what it was back then, did not always catch that the metal was sometimes not actually punched/knocked out. So when the tire machine (which was building up rims/tires to keep up with a moving assembly line) went to install the valvestem, if the hole was not there, the stem would just fall on the floor. Meanwhile, the tire got inflated as normal around the bead. If not caught, the car sometimes went to the dealer like this. Imagine the owner's or tech's expression when they went to check air pressure or add air and found no valvestem....!! Would have been a great Alan Funt/Candid Camera video!!
I’ve heard you can fill them with estrogen for a softer more gentle ride….
You may end up with a more passive-aggressive ride doing that...
It's compactedThe stuff in those small donut tires must be real expensive with those tires being so small. Can’t even afford to fill a full size tire.
Down here in aussy land we sell clean air in a can ! I don't know about winter and summer air because we only have good days and even better days! Just need to get rid of some of those pesky kangaroos trying to steal my mopar!
As he picked up his hammer a saw.Aaaaa. I see now said the blind man.
There’s a song there somewhere. Haven’t figured it out yet but I’ll let you know.As he picked up his hammer a saw.
Maybe it was a book.There’s a song there somewhere. Haven’t figured it out yet but I’ll let you know.
Multi vis air read about it once along time ago in popular mechanics but have never seen it on the shelf. Is it available at Walmart now.I don't know why you guys are going through all this trouble. Whenever I get tires mounted I just ask for the multi-vis air. They give me a strange look but go ahead and do it. It has worked well for many seasons. I'm pretty sure the synthetic, multi-vis air is the way to go!
Sure, its fine on the modern aluminum rims, but if you still run magnesium rims OR bias ply tires you have to ad zinc when running multi vis airI don't know why you guys are going through all this trouble. Whenever I get tires mounted I just ask for the multi-vis air. They give me a strange look but go ahead and do it. It has worked well for many seasons. I'm pretty sure the synthetic, multi-vis air is the way to go!
It also has to be Vegan doesn't it?Sure, its fine on the modern aluminum rims, but if you still run magnesium rims OR bias ply tires you have to ad zinc when running multi vis air
