I want to know, Can I just take any gauges and swap em into my car?
360-68cudu
California
Is it possible to take any gauges from any car and put in my Dash? what would be the possible problems with that? I figure id find some nice gauges at a Junk yard and switch em up.
"It depends" You'll have to do some research. Ford, for many years, used gauges that used what is essentially the same voltage limiter as Mopars, but the resistance of the sending units might be different. So you might have to use Ford temp/ oil sending units, and figure a way to re-work the Mopar fuel sender to suit.
