abdywgn
dismantler
Is anybody using this brand for a street/strip engine? Any specific likes/dislikes? Thanks! Bob
anyone know where I can get a set of IC969 .020?
I guess i should drive to Carson City since I am in Reno...LOL
The KB's seem to be heavier than any other piston I've looked at, like 100 grams heavier.
LOL...HUH?? The pistons we used in the Car craft 410 are shelf pistons and weigh about 600g. with pins. Not heavy at all.
They are by far cheaper than any other brand and you get custom type reliefs to boot.
Most of the icon #'s are in the 500.00 range and some less!
From Hughes engines site;
KB pistons
C.D. Approx. Weight Pin Size CC's Comp 64cc Comp 68cc Comp 72cc
1.465" 638gr .984" X 2.750" -20.5cc 10 9.6 9.3
Diamond pistons
C.D. Approx. Weight Pin Size CC's Comp 60cc Comp 65cc Comp 70cc Stroke
1.457" 502gr .984" X 2.750" -20.0 10.0 9.5 9.1 4.00"
So 136 grams is laughable?
I'll bet that Diamond piston weight is without a pin. There's no way your going to get a typical shelf 408 piston down to 500g with pin. Double check that there mr. jones....
An Icon IC745, same piston that hughes list, is 517 grams without pin.
Pin is 118 grams
Total 635.
http://kb-silvolite.com/test/icon/icon.php?action=details&P_id=325
The diamonds are without pin weights, I've spoken with them and asked that specific question, add about 115-125 to it for the total
http://www.diamondracing.net/MoParSection.pdf
I'm not surprised hughes doesn't have an apples to apples comparison on there site. be nice if they actually listed the item with the piston/pin and a total.
thanks for all the info here guys! I would also like to know if they are made in the US.
KB is 517 grams and Diamonds are 502... inherently heavier???
With the pin they are both in the 620-640 range.
Roughly 4 8-balls difference.... crude 80's reference. :toothy10:
And what about the 575 range with pin for the SRP's? These are just three different piston manufacturers, I'm sure I could find more.
first it's KB's are heavier by over 100 grams then a diamond, they're not.
KB list the weights as a piston/pin split on the site.
Now throw a SRP in there that lighter than both.
