Yes they had my 76 column and a 72 column to create it from. I had mine made tilt wheel floor shift but they can do a column shift as well. The one I took them was a column shift.Is this a 70 and up tilt/column shift column?
I'm curious, are they building it with a collapsible shaft like the factory unit?
I was just about to pull the trigger on an Ididit or Flaming River column for my '60 Dart, but when I asked if they were collapsible columns they both said no The only reason I wanted to upgrade was for an added measure of safety.
I think your column is the one that was made with the GM Key setup. They said they were going to make mine with the chrysler key.It was my donor column that got the ball rolling. Should be a good product but I wish they would dump their goofball key setup.
I know they are expanding their catalog, the best thing to do is call and ask Kelly.Do you know of any plans to offer the earlier keyless column?
sorry guys been gone for a while. I just picked up the dart this weekend from Ididit. They had it longer than they expected. They wanted to make the brackets fit better and then powder coat them to make them look nice. The car is still on the trailer due to finishing up some other projects before woodward but after woodward it will go in the garage to get its wiring finished.Any updates?
Well?sorry guys been gone for a while. I just picked up the dart this weekend from Ididit. They had it longer than they expected. They wanted to make the brackets fit better and then powder coat them to make them look nice. The car is still on the trailer due to finishing up some other projects before woodward but after woodward it will go in the garage to get its wiring finished.
Thanks for the update Sir. By any chance do you have a part number of sorts? Spoke with Derek today, he made no mention of a specific column for an A-body....fit is great, when I rewired the car I switched over to a mallory ignition and I had to get their time delay relay pack to keep the car running while it switches from instant start to run. I like I how it looks just have to quit putting little projects on the car and drive the thing..
