Odin
The bearing in the idler pulley on my 69 440 is bad and squeals loudly. I’m looking for a good one to replace it but the local parts store can’t get one. It’s part number 2240397 and fits all Chrysler engines from around 62 to 74. If you look in the pics you can see it has a flat-sided stud through the bearing and the other side of the pulley is sealed with a couple factory spot welds. I might be able to make another pulley work but I would like to find this one before resorting to that.
