If I could change just one thing around here....
Jimmy
74 Swinger
Vancouver
Stickies!!! Seriously the same questions get asked over and over again, if you do a search for any given subject you get a bunch of posts where half the problems, pitfalls and tricks are answered and if you check the right 3 posts you can piece it together, but miss one and your sol. A post with a concise all encompassing answer to all possible variables on the most popular subjects is what I'm saying. I love this forum and its users have saved my *** and money plenty of times, I'm just saying a sticky or two for the most asked questions couldn't hurt. When I make a post, I get the correct answer for my particular problem, but if I try to avoid crowding the forum with redundant questions it can get very confusing very quickly.
Example? Ok, so PS to manual swap. What would you search? I tried such exotica as "PS", "Manual" and "Swap" and found the question has been asked many many times in both directions. I read through a bunch of them and gleamed that I would need to A:lengthen the PS shaft with an adapter or swap the shaft from the manual column B:Use the pitman arm from the manual box. 3 identical responses later I figured that this must be what I have to do and what I need to know. I have a 74 Dart with PS, the manual box, arm and column I purchased were from a 72 (ok calm down if you've heard this one). So after taking the day to get the parts, laying down some cash, prying out the manifold (exhaust compression seal seriously seized), removing the column, yanking out the PS upon installation of the manual box I realize that the tapers on the pitman are in the wrong direction. So I think to myself I must have read it wrong all three times, I have to use the PS pitman obviously. So off to the store I go for a puller, pop pop and wth? It's too big? So off to my trust FABO I go and this time search the obvious "Pitman" and come across a guy immediately with the same problem, the boxes have to both be pre 73 or post 73. To mix and match requires a new center link and idler arm. I wished I had searched pitman but pitman was the answer to my question not the question itself. This is my luck it seems but also the way of the mopar as my short year and a half working on the dart have taught me. Nothing is ever as simple as it seems. I ran into almost the exact same problem when I did my ball joints, when I sized out my wheels and tires and when I tried to figure out which mounts to use for my engine swap. So from now on I am going to post my own question and get my own answers which will probably confuse someone else and the circle continues, but Ive learned my lesson for the 4th and last time.
I guess people don't know what the search button is for.......
:sign3:
That's sort of my point, lack of stickies creates redundant posting which makes searching futile. I love search, I would much rather figure it out on my own than let everyone tear me apart for not knowing everything already.
I totally agree, I was actually about to propose a sticky on "entry-level" mods to stock 318 cars, this seriously gets asked at least once a week.
But the social interaction is what makes FABO so special!
LOL
:coffee2:
Anytime I find wierd stuff for Abody and find the solution, I try to post here. 2 month nightmare and 5 idler arms delivered before I knew I needed the "Yes for police and taxi service units" idler arm for my more door 74 Lump. Sometimes too you just run into factory anomaly with parts that seem they were for a different car but are on yours from the factory! LOL
I see the same questions repeated but I'm sure that's because I spend too much time here. The complete oposite of the norm would be post all the relevant factory service manuals to read online and remove the post questions option.
The fact that a newbie can sign in here , ask a question, and get an answer almost imediately is what makes this forum so successful. Just my .02
I do try and do some searching, but not knowing the "innards" of how this site works, I wont criticize the search function, but like Redfish said the interaction is what helps work the wrinkles out....if ya know what I mean
I think the search function is great. Being new to Mopars, my problem is not always knowing what to search for. For example, the "thing-a-ma-bob" that connects to the "weird looking piece" on the steering column.... That said, I like the idea of stickys for common types of fixes and mods. Planning on photo documenting my progess when I tear into the steering gearbox that needs replacing. Might be a good candidate for a sticky?
Have a good one folks,
Pat
X3 if you take all the questions out that has been asked before you would have a pretty empty forum and all our mopar guru's wouldn't have anything to do. I kinda think they enjoy sharing their knowledge with dumbies like me. And some times I need a lot of extra help ( I'm old) seems like we are trying to fix something that isn't broke. Jmo
Moe
Would have been nice if this was in the right forum......this is the steering forum after all....
Well,I guess I'll put my .02 cents in !!! I understand how redundant it may seem to some ! But as I,a simple person of age with no Formal Teachings,as well as Techno Skills don't always find what I'm looking for !! So just how much does it really Hurt any one of the numerous knowledgeable people on this site ?? To me it's sooooo much easier to ask the question, than to spend forever looking all over the place for the right answer,then still come up empty handed !! I for one am slow learning,therefore repetitive responses help things sink in !!:violent1::violent1:
Well it is a diatribe about a PS to manual swap going wrong as much as it is about stickies. If someone searches "PS" "Swap" "Manual" I wanted them to find this post.
And to all that are saying the board would be empty if we answered all the questions..
I'm not saying post every answer or the manual, hell I have the manual and its no help half the time and it would be impossible anyway, just the most relevant information on a subject, or at least a DIY. Almost every other forum follows this formula.
If you look at any given post here you will see that the replies are outnumbered by the views 100 - 1 meaning that 99% are just searching and not posting already so why not give them some of the answers they are looking for? People will always post questions, this way they would just be easier to sort through.
ok my 8c are counted. going to go find a center-link and idler arm now.
