Ign switch problem
BWDart
New Braunfels TX
72 Dart went to take key out of switch and it won't come out also switch won't go to acc position start and run are ok what do I look for? Worked fine last week argghh!
You have to pull the steering wheel and lock plate. There is a tiny hole where you need to push a brass button on the lock cylinder. I have my doubts that it's the cylinder however. Will it turn to the Off and Lock position? You may have a bad ignition switch. I'd disconnect the battery before I got into the column.
AbodyJoe has a nice write up here on the board on "how to" do this
If you don't have one, wander over to MyMopar and download yourself a free factory service manual.
