What temperature is "hot"? Normally, it will get warm, maybe so you can hold your hand on it for 10 sec. If so hot you can only touch it < 1 sec, that is "too hot". At that point, your spark will start missing at higher throttle. How I know, I hot-wired +12 V straight to coil+ to drive my Valiant home after it stopped from a problem in the ignition supply and it ran fine for 5 minutes until the coil got too hot, then started missing above 40 mph. Jumpered in the ballast and ran fine.
