SpriceyStuff
Hey guys! I’m having a lot of issues with my Dart. I’m like 12 weeks into my weekend project now. I had pulled the engine to do a bearing swap and put it back in. It ran prior to pulling the engine. After I dropped it back in, it would only run while the starter was engaged. After disengaging the starter it would die. I believe this is due to the fact that the ignition switch had come apart with age. After some fiddling around, it now no longer fires. I’ve checked my wiring according to my schematics, to no avail. Everything appears to check out. All I know as of now is that the field is not being interrupted and the coil is not firing. Any advice, ideas, or possibly some life saving personal experience to share?
