schwinger
1972 Dodge Dart Swinger
having trouble figuring this problem i have. car starts and idles good but after a couple minutes ballast and coil heats up to where i believe it kills the car.
Its getting fuel, new filter, new fuel pump, carb is good, new sparkplug wires, spark plugs, fairly new distributor, alternator, voltage regulator, coil and battery. Started throwing new parts to it and it hasnt solved the problem.
Points type distributor, and its a 318. Problem started ever since i replaced the distributor with a new one and already went thru 2 new distributors.
