well I back. I am not good on electrical problems but I know alot of you guys are. Checked the wires going to the broke connector and I am getting power to the red wire so I figured if I connected a remote start switch to the red and then tried all the other wires I should get a reaction from the starter, but nothing. Also I have a long black wire coming out of the fuse block and need to know where it goes ( the wiring diagram didn't help me ) Also if I hot wire the battery to the coil the engine runs. So any advise will help, you guys helped me before.
could it be abodyjoe?
Where does the black wire from the fuse block go to, there is a black wire already on the ignition switch ?
THis should help
http://www.mymopar.com/downloads/1963/63DartA.jpg
http://www.mymopar.com/downloads/1963/63DartB.jpg
Go do diagram A and find the ignition switch towards the bottom of the page. Your switch should look just like the drawing. The connections are:
RED is unfused power coming IN to the switch from the ammeter circuit, a splice in the harness
BLACK is "switched" power going to the fuse box "acessories" buss
YELLOW goes through the bulkhead to one of the push-on connectors on the start relay
BROWN goes through the bulkhead to the coil + side of the ballast resistor, and provides hot 12V when cranking to the ignition system
DARK BLUE is ignition run and is NOT fused. It supples the gauges in the dash, the ignition system and regulator.
While you are going to this trouble you might consider pulling apart and inspecting the bulkhead connector. If you cannot get a replacement switch connector, I"d just use individual push on connectors.
Needing a hot jumper wire from battery to coil is a different problem regardless what ignition switch is used. Could be the ballast resistor or several other things.
Your ignition switch sends full 12 volts to the coil in the start position via one wire in the start position and via different wire in the run position.
With a jumper to the coil neither is diagnosed.
