rod7515
Im working with a 66 Dart, 270 Automatic. I've totally removed the wiring harness under the hood and also under the dash. Its a good harness as far as its not been chopped or hacked, but I've upgraded the engine to a 408, will be moving the battery to the trunk, replacing the amp gauge to a volt gauge, adding a headlight relay upgrade and putting dual electric fans for cooling. Also will need to add fuel pump relay, line lock solenoid and probably some other things Im not aware of yet. I am also going to newer electronic ignition. I plan on doing some drag racing with this and would like to hide most of the wiring out under the hood. Was hoping with the great expertise we have on this forum I could get some good advice on how I should tackle this. Also where is the best place to buy terminals and ends along with wire? Gauge recommendations? My bulkhead connector looks to be in great shape so I could continue to use this. Looking forward to any suggestions or help you can pass on to me. Any pics of what you have done with your upgrades? This project is probably going to take at least another year for me to finish so its not like I will be jumping right into this. Just planning ahead and trying to learn as much as I can before I jump!
In advance, Thanks
Rod
In advance, Thanks
Rod
