holychrysler
holychrysler
So, I have a 1963 plymouth valiant 2 door post. All original 170 slant six 1 barrel brand new 2" single exhaust. 3 speed manual on the "tree". It runs and drives wonderful. BUT,,,,,,,,,I am REALLY wanting more power. And fuel economy would be nice. I was going to convert it to a two barrel carb followed by a turbo set up. And bucket seats and floor shift 3 speed overdrive. Now im thinking that I will put in a 5 speed overdrive that I have. This transmission has the shifter on the inside and comes out the top. Which would eliminate the offset floor hump, hurst compitition shifter that I dont have shifting rods for. And I would have to switch it over to hydraulic. Anyway, I want to put a V 8 In it. With all the things that need to be changed over for just a 273,318,360 I think I might as well put a big block in it. I have a V6 that is basically a 318 with 2 cylinders cut off, a good running 360, or a 383. These are motors I already own. I have the 3 speed in my car, two 3 speed overdrives, and the 5 speed overdrive that is coupled with the V 6. I have a stromberg 2 barrel in good working condition, a two barrel weber in good working condition, a holley 4 barrel in good working condition and an edelbrock 4 barrel in good working condition. I have bucket seats from an1971 road runner with seat belts from same vehicle. My original bench seat is broken on the drivers side. It has to be held up with a chunk of 2 by 4. They are high back buckets but in good shape. I would prefer low backs but I think these will be just fine. Anyway, now you know what I already own. Im trying to spend the least amount of money as possible. Oh, and by the way, my car has the stock 323 suregrip 7 1/4. And original springs. I have a ford 9" from a 66 mustang with 390 gears and posi. With all that said, now you know what I own. What are your thoughts and/ or suggestions? Thanks.
