[WANTED] Information for routing heater cables on a 66 barracuda
Not an easy thing to photograph without taking the car apart. I can describe where each cable goes if that will help. The defrost cable goes to the left flap connection (center of the dash area). The same lever controls the heat also, so, it's other cable goes to the middle flap connection, and the temp cable to the flap on the right side close to the fresh air section.
Thanks for the info i believe it will help. Thanks
