dustoff440
Heres my set up
stock long block 1993 360 magnum stock heads(good springs),
stock compression 9.1 to 1,
air gap,
750 vac sec holley
hedman headers 1 5/8
loose 3500 converter
3.91 sure grip
100 horse nitrous
512 lift 278 duration hydraulic roller cam
MP adjustable distributor
I bought the distributor from another FABO member who has it set up at 8 degrees advance(16 at the crank) with the advance starting at 1200 and all in by 2600. I am going to set it up at 18 before tdc for a total of 34 degrees as an initial set up. Does this sound like a good starting point to begin the tuning. Has anyone had a similar setup and maybe have a chart that worked well for them. The car weighs 3500 with me in it. Does my hope for about 12.40's sound reasonable??? I'm figuring with the nitrous I'm should have about 450 horses at the flywheel, does this sound like a good estimate?? The motor if I'm not mistaken the only difference between the 380 crate and this is 14 more degrees duration on the cam, a dual plane instead of the single plane, and a point of compression. Im figuring that there is a 30-40 horse difference between the two which would bring me to about 340-350 horse plus 100 horses for the nitrous equal 440-450 horses???????????????????????????
air gap,
750 vac sec holley
3.91 sure grip
100 horse nitrous
