Duane
I only took mine out on this build because I wanted to verify the size of the drilled hole which I am glad I checked because it was not drilled to 1/2 inch all the way. I drilled the hole and installed new plug with green loctite and verified the position.When the plug under the main cap is left out it doesn't send all the oil out to the filter. I usually don't take that one out as you can get to both sides of it.
The threaded plug that is at the end of the drivers side lifter gallery should come out so you can get it clean. If you forget to install it you'll have very low or no oil pressure.
