installing manifolds
jazak5
NY
motor in car
69 340 barracuda
what's easier //removing master cylinder and sneaking the driver side in or popping a motor mount and lifting the engine ?? or some other method??
Take one nut off the motor mount and jack that side of the engine a bit. Much easier than messing with the master cylinder.
if they are 68 -70 hi flo manifolds you should be able to "fanagle" them in.I've never
had to raise the motor or ...
Used the 68-70 340 manifolds when I did Jamie's dart. Raised the driver side of the engine some to get the manifold in. I swear the time headers were easier to install on my dart. :)
use the log style, a blind man can put them on and not scratch the paint :D
weellllll, got the manifolds in !!!!!! Driver-side went in from the TOP!!!
1.removed plugs
2. the steering coupler is a rectangle (make sure the thin side is up/down)
3. slide flange past steering shaft first whola!
my car is a NON power brakes
