instrument cluster voltage limiter
I was looking at this retrofit Solid State Voltage Limiter for my Dart.
It's Plug and Play, which works best for me as the dash is in use...
http://www.rt-eng.com/mediawiki/index.php/RTE_ABlimiter
Hey what year dart do you have? Do you have photos of your instrument cluster with the IVR4 or 3
I have bought them for $30 on ebay. By tweaking the output voltage, I could get my temperature gage to read perfect. Of course, need another "knob" to get the fuel gage also correct, so I installed series resistors on the back of the cluster for that. I also tweaked the slotted needle adjustments in one or both gages (careful not to break).
For those suggesting "why not just 12 V sensors?", would you really want 12 V on the fuel level sender in your fuel tank? That is 6x more power available and much more spark potential. I know the gas vapors should displace air, but investigators think one airliner (Swiss-Air from NYC, I recall) exploded due to a frayed wire in the fuel tank.
I've tried using both a 7805 and a variable one calibrated to 6.0 volts output. I find what's needed is exactly 5.0 volts so I simply use the 7805. I test my gauges on the bench using an 11 ohm resistor (exactly) in series, I find it works well. As stated above, you need a heat sink for the 7805 or it won't last long at all. Mine is not a higher current device and has lasted for over 3 years now (with a heat-sink) but it is a good idea to use the one rated for more current.
I'm bringing this back for a question.
I ran the 7805 set up years ago. Never drove the car much to see how. Accurate it was. I was just happy to have the gas gauge back working.
I ordered some 7805s. Should be here in a few days.
However......
I can get a 7806 6 volt output right now. What will this do?
Make the gauge more accurate?
or make the gauge and burn it out over time?
The 7805 isn't exactly 5.0 volts. Even though its a modern solid state piece it aint everything some think it is. At 68 degrees, initial output should be 4.86 to 4.92 . As it warms it'll climb to 5.2 for a normal/average and all those numbers vary slightly with mfgr. It can go 5.4 and more depending how hot it gets. Digikey once substituted the brand I had ordered with some other brand. initial output was in the 4.6s. Yeah, Digikey got a message. In any case, Efficient heat sink is a must.
