Intake for 1965 273
GreyWizard
Colorado
? for the experts. Can you modify a 1966 and up aluminum intake manifold to fit 1965 heads?
Thank you in advance.
David
If you are wiling to wallow out the bolt holes to modify the angle, yes. The ugly enlarged holes can be hidden by flat washers.
I used to do it regularly when 273s were more common. Did it for friends cars too, even with iron manifolds. (66 &67 four barrel 273s to the 64 -65) I'm sure others on here have done it with good results as well.
That is good news. Thank you.
