Interesting Valve Springs Article
Yes thank you
have heard of nature stress relieving, heat, and chyro, but never vibration or frequency stress relieving.
Good article
It seems the author believes there are only Chevrolet engines in this world.
Very good article. I haven't tested oils against HR lifters since the mid 2000's but at that time, if you used a thin oil the HR lifter would go through different...for lack of a better term...a harmonic. You could see it on the dyno graph.
The two things that made it go away were a heavier grade oil and the stiffest pushrods we could get in there.
That may have changed though, as I talked to a source a few years ago who assured me they are different now.
I'd only believe it if I tested it myself. And I don't use HR lifters any more.
