Is 3.5 inches the right size for rear spring shackle?
65s
Ottawa, Ontario
The Dart Sport seems to ride really high at the back. The rear shackle is 3.5 inches from bolt center to bolt center. Is this right, or is this a longer than stock shackle?
Okay, thanks. It sorta looks right to me, but I have nothing else to compare it to right now.
There's some weird shocks with springs around them installed too, maybe that's what's giving it so much height.
Oh yeah them booster springs on the shocks will lift it. You can probably remove just the springs from the shocks and lower it unless their some special shocks that don't come apart. In the old days it wasn't uncommon to add booster springs to the shocks to lift the rear when the springs got weak instead of replacing the springs.
