IS A ‘65 383 BLOCK DIFFERENT THAN ‘66-72?
Troub
67 Dart 270, 225 slant six
Florida
I keep seeing notes in the product specs for new heads, intakes, etc…. That say compatible for 383’s ‘66-72…..will there be issues with my 65 383 block accepting things like new aftermarket stuff?
Here is an example from Edelbrock for their intakes…..says 1958-…… in title but 66-72 in description. Or am I reading it wrong?
Probably because of the intake openings matching the heads, they will all fit buy may not be 100% correct with the smaller opening heads...
Are early 383 heads closed chamber ?
If so that may be the difference.
there are 2 383 blocks a b and rb the rb is a older casting from the 50's , earlier 50'and 60 heads have rocker shafts that bolt to stands holding them to the head and less valve cover bolts, you would find the tall block 383 in a lot of trucks
Cam kits show as fitting 67 and up. The reason is that the lifters in pre 67 big blocks had a smaller cup and used a pushrod with a tapered end and a smaller ball on the lifter end and standard size ball on the rocker end. I ran into that on my 66 361. Luckily Kim had a brand new set of early style Johnson lifters. I could have used newer lifters if I had switched to newer style pushrods which had the standard ball size on each end.
Makes sense. I was thinking it might have something to do with the valve train.
