is my wiring correct?
swing69
I’m just an old guy……
Central NJ
Here is the wiper switch and ignition switch wiring for my 65 Barracuda.
Other than the molded plug, does anything go on the B tab on the ign. switch?
Wiper switch: molded plug no problems. But the white single, and the other two singles (red and yellow)....are they on the right terminals????
TIA
Per my factory wiring diagram, it looks like you have it correct for the wiper switch. and the ignition the book doesn't even show a BA terminal so I think your good.
You can also download free wiring diagrams for your at www.mymopar.com under tools and reference. and it's a black and white diagram but does indicate the wire color on it. Should of mentioned it in my first post...
