growdude
Disabled but not dead
Is there a way to put rear disc on 8 3/4 using all Mopar parts no mustang or Chevy parts.
you can use the rear brakes from certain year Grand Cherokees. Or call Dr Diff aka Cass and ask himIs there a way to put rear disc on 8 3/4 using all Mopar parts no mustang or Chevy parts.
The imperial set up is ideal but way to pricy for me
Pricey and like the seller stated rotors are impossible to find if needed.
Optional.I wonder if rear discs were standard or optional on the Imperial, guessing optional.
The calipers are the same as the later A-body front calipers (I.E. cheap and readily available).You "might" be able to come up with "all Mopar" but remember that lots of that older stuff is not really readily available........next time you need pads, rotors, calipers, hardware.............
The 8 and 1/4 and 9 and 1/4 can use the same backing plates the eight and three quarter and the Dana 9 and 3/4 use the same backing plates but you cannot just Bolt the nine and a quarter backing plate to a eight and three quarter or Dana.
