Is there a way to identify a Hi or Low horn?
340doc
Dunnellon Fl
My sons Dart came with one horn mounted at the top of the core support. The wire is there for the other horn that goes below it. I believe its a HI horn but I was wondering if there's any way to identify the Hi from the Low if I find some at a swap meet?
That's the info I was looking for! Thanks Sedanman! Gonna have to take his off and clean it up so I know where to look.
Yea there is . the low horn will sat "Spartan" followed by, in small letters, "lo", and is usually plastic coupled with metal . the high horn is usually all metal . Which one goes where doesn't matter.
Good info, thanks.
The Hi horn has a smaller cinnamon roll center that leaves about an inch around the outside as a flat, the Lo horn cinnamon swirl goes almost to the lip of the outside rim!!
They vary with year. The original for my 64 Valiant is just a single, at least I think since what was in it and matches internet photos. Regardless I have M-B horns on both A's now since they are small and come on the radiator pusher fans I added.
