Is this a fair radiator?
Tad
Not here
I’ll admit from the start I’m going cheaper and trying to avoid buying a $900 radiator. This is for a second car that is a daily driver. Running a 340 that gets up around 200+ within 15 minutes or so. the radiator is too small I believe. Looking for something to put in to cool the engine better. Has anyone had any experience with this company?
I used this one . It's a 3 core, in my cuda with a mild 360 and have no complaints on it. It fit good , hat to drill 2 mounting holes.
There are so many reasons that the rad is not "too small"
  1. Fan type
  2. Number of blades
  3. Pitch of blades
  4. Diameter of crank pulley
  5. Diameter of water pump pulley
  6. Number of impeller blades in waterpump
  7. Thermostat temp (if it is a 195, 200 would be a normal temp)
  8. Where and how you are measuring the temp
  9. clogged radiator passages
  10. Clogged water passages in engine
  11. Number of rows in rad
  12. Fins per inch between tubes
  13. Aftermarket fan shroud
  14. Lack of bypass hose.
  15. Engine mods
  16. Timing
  17. Carb lean
What did I miss?
Start with what the factory put in a 340 car. Then "improve" from there.
What year Cuda? Going in a 65 dart here.
Then you don't need to buy a Charger radiator. It's a gamble with the chinese radiators. Sometimes they are great and sometimes they aren't.
Do NOT waste your cash on a 3 core radiator. Look into Cold Case radiators here on FABO.
You want the largest 2 core radiator you can find, a high flow water pump, a QUALITY Stewart Components thermostat and, and this is a big AND, if you want maximum cooling you need to measure your pulleys and turn the water pump 20% faster than the crank.
You do that and you will cool the engine in the hottest climes without an issue.
Stay away from 3 and 4 core radiators. A big 2 core is much, much better.
Cold Case radiator. Look them up here on FABO.
I used CC1635 in my 65 Barracuda w/904. You do have to drill the mtg. holes but it fits. I would also recommend a hi flow water pump for optimum cooling of high performance builds. 65'
Cold case is reasonably priced. Yellow Rose makes a good point about 2 row. I didn't know then what I know now when I bought my 3 row Champion.
Is there a product to put in that would clean/dissolve clogs?
  1. Fan type: steel
  2. Number of blades: 7
  3. Pitch of blades: unsure
  4. Diameter of crank pulley: equal to water pump
  6. Number of impeller blades in waterpump: 8 blade 2951571 reman
  7. Thermostat temp (if it is a 195, 200 would be a normal temp): need to check
  8. Where and how you are measuring the temp: at thermostat housing and top of radiator
  13. Aftermarket fan shroud: NONE
What did I miss?
Is it getting to temp while idling or driving in 15 min?
What had been done to the engine, rebuild?
Initial timing?
Is it running lean?
View attachment 1715494792 I’ll admit from the start I’m going cheaper and trying to avoid buying a $900 radiator. This is for a second car that is a daily driver. Running a 340 that gets up around 200+ within 15 minutes or so. the radiator is too small I believe. Looking for something to put in to cool the engine better. Has anyone had any experience with this company?
First thing you want to do is follow some of the good advice provided by the members. It may be something simple that brings your temps down without having to replace your radiator.
I'll be very honest in saying that a lot of aluminum radiators are sold prior to digging into the 'real' problem. But it's still a valid solution. Some owners don't want to take the time to trouble shoot. Some owners realize it costs more money trouble shooting than it does to just buy a new radiator. aluminum + fluid volume can cure a lot of evils going on in your car.
That being said, if you decide to take that plunge, for just a little more than $274, you can get an aluminum radiator with OEM style stamped tanks and a much bigger volume core.
As a sponsor, Cold Case is running a 'online Car show special' because of the cancellation of all the car shows this Spring. That means we're offering show pricing and free shipping right now. Additionally, we started a $50 rebate program that can reduce your purchase price yet another $50.
It's something we've never done before but if we can help our customers while at the same time keeping the lights on, it's a win win for both of us. :)
Initial timing?
Is it running lean?
If it sits and idles it gets hot or idling in traffic/barely moving. Once I start moving again at higher speed the needle drops.
The 2 core vs 3 core thing is mostly just a gimmick, especially the way that they’re marketed. You won’t find any useful engineering specifications on any of the vendor websites, just cutesy drawings and ridiculously oversimplified, pseudo scientific explanations. There’s a lot more that goes into building a good radiator than just the number of cores. There are plenty of 3 core radiators that work great and will outperform 2 core radiators. And there are two core radiators that will out perform 3 core radiators. Heck, the factory used 3 core radiators, and I can absolutely guarantee they did far more testing and analysis than the vast majority of aftermarket radiator manufacturers. Just saying a 2 core (or a 3 core) is better is meaningless by itself.
I run a 26” Champion 3 core on my Duster. It has a .060” 340, 9.8:1 compression, ported iron heads and a decent cam. It’s a lot more to cool than a factory 340. I run a set of Ford Contour electric fans, and frequently drive my car in 100+ degree temperatures, even in traffic. I’ve never had an issue with overheating, and I spent less on my radiator and fan set up than a Cold Case radiator by itself.
I’m not saying Cold Case radiators aren’t good or that they don’t work. It seems like the members here that have used them are happy, which is great. But I’ve yet to see them post anything that can actually be used to prove they’re any better, and I’ve asked. There are certainly less expensive options that do work for people.
And I’m not some Champion radiators die hard either. They have had their issues, and I would definitely suggest buying one from a known vendor in case you do have a quality control issue. I drilled the mounting holes in mine. But I’m ok with that too, for $200+ in savings I can drill a couple holes.
That’s probably NOT a radiator issue. That is more likely a fan issue, as it’s indicated the issue is not moving enough air at slow speeds. If it cools off when you’re moving and doesn’t creep up on the highway under load the radiator is likely ok.
Your picture shows no shroud, BIG no-no, and your looped together heat hose is returning hot water right back into the block. You basically need more airflow through the radiator, and fix some of the "hacking" there
Yup!
I should’ve looked more closely at the picture. The lack of a fan shroud by itself could be causing the issue.
Really, 200+ degrees is not unusual in traffic. And that assumes your temp gauge is dead on. If it stays under 220 I wouldn’t consider it a big issue. And the missing shroud really hurts fan efficiency.
If you can get the fan close enough to the radiator you don’t need the shroud, and the shroud VN be an issue at higher road speeds.
The OP needs to get the water pump (and the fan) turning faster than the crank and then go from there.
I agree the 2 core 3 core thing is probably a fart into a fan deal, but the OP didn’t have a radiator yet, so I think the 2 core is a bit better. If he had 3 core I’d have said leave it alone and look for other things.
So I agree with everything you posted.
I vote read post #5 again Then again. A few other comments followed that also matter.
Back in the day these cars cooled just fine OEM and yes there are some other things that can help today, too. No reason a good 2 core is not totally adequate IF everything else is correct! Post #5!!
Thank you. I’ll work on the shroud. I had the heater hoses block off and was told it would be better if they were connected. Is there another solution?
That is 1:1 and that is WAY too slow. Fix that first. In a bit I’ll screen shot what Chrysler says about water pump speed so you don’t have to take my word for it.
If my current 2 pulleys are 6 3/4 what smaller size should I get for the water pump?
Here is what Chrysler says about pump speed. They want the water pump turning 20% faster than the crank for maximum cooling. I suggest you get as close to that as possible. I’m only 6% overdriven, but I’m working on getting it to 20%.
You have a 6.75 inch water pump pulley. To get to 20% overdriven, you’ll need a crank pulley that is 8.10 in diameter.
At 10% over you’ll need to be just over or at 7.45 inches.
I don’t run a shroud. Your fan is plenty close enough to the radiator you won’t need one if the pump is turning the correct speed.
Fixed my damn math. Sorry for the confusion.
