[WANTED] ISO speedo gear for ‘65 904LA tranny
Arizona
Former Yooper, always a MoPar fan.
Gilbert, AZ
I need the speedo assembly for a 65 Dart 273. It is a 904-LA transmission. Let me know if you have one, please send/post pic. I need the gear, shaft, housing, and retainer. The hole in the trans is 1” and the spline to match up with is in about 1 1/4”. Not sure how many teeth I need to get it right. It is the smaller rear end but I changed the tires from the original 14s to 195/r65/15s. So... I don’t really care if I get the gear tooth count right at this time, unless it has to be a certain one for this trans? I just need one that fits for now to get the beast running and driving for the first time.
Thanks
Jim
All I have is a hole for it to go into. It is a 904-LA transmission. Let me know if you have one, please send/post pic. I need the gear, shaft, housing, and clamp.
Thanks
Jim
Looks like you are selling one.
It looks right from what I see, but I don’t have the original to compare with. Do you know what it is out of? And how much do you want for it? Thanks!
I believe it's from an early A body but the gear is for a 3.23 with a 24 inch tire. or 3.55 with 27 inch tire
By “they” you must mean me... I would be glad to move it to the wanted section (sorry I didn’t see it before, used to seeing many posts in for sale with ISO in the title). But I don’t know how to move it... or do I simply start over? Thanks!
I already fixed it. We have highlighted titles here and don't use the ISO thing. Simply put, if you are looking for something, you start a wanted thread. If you are selling, a sale thread. Read and understand the sale rules before posting. If you do it wrong your thread may get deleted.
Post pictures of the transmission in the "Wanted" section, we cant see it from our houses.
Here is what I have... the hole is 1” and the spline is in about 1 1/4” from the surface.
Working on moving this to wanted if I can, or I will start over there. Thanks.
Will the housing fit in a 1” hole? If it will, how much $$ do you want for it? Thanks
I've been doing this for 60 plus years and have never seen a speedo housing that small. This one is 1 3/4". Sorry I can't help you
I can’t tell you how many times I have been told things like that. I must attract the prototypes of everything... LOL Oh well I will keep looking. Thanks
That might be the hole for the park shift cable. 65 have cable operated shift.
I was just thinking about that, looking on the net for a photo and wondering if the op would take a picture of the side of the transmission where the hole is but not so up close like the last photo. There's something screwy here I think.
Looks like the speedo cable hole to me. I think I have a gear, but, nothing else.
Here is a pic of the trans and of the service manual. The park-lock cable is ahead of this hole on the underside of the trans in this pic.
Do you have a transmission shop in your town? I could see a guy having one of those in a box under the bench or in a tool box drawer.
Every pre 66 trans was like this. What is so hard for folks recognize? Ive been doing this for only 6 years, and I know it. Plus I have speedo gears. arizona can pm me if he wants a particular tooth count.
Good thing you stopped by.
From what I see the speedo cable and housing are a single piece. It also looks like the gear inside the trans is not included, so if I get this one I will still need a gear. But this is the main part.
Yes, you'll still need the gear and clip. Do you have the cable retainer and bolt?
No, I don’t have anything at all. I can get the cable and housing (reproduction) but don’t know about the gear/ clip.
I have the complete setup. OEM A body cable and a choice of several tooth pinion gears. $100
PM me to discuss and leave contact info.
