PRH
I’ll take the cubes.
I simply want to drive to the track on a hot 85/90 degree day in my stock appearing 71 demon 340 6 pack, drop the drag radial pressure a bit and click off a easy 11.50 short shifting, maybe last pass of the day shift it up around 6,500 + for a low 11 pass as they kick me out! So for guys like me with ported J's, 3500lbs race weight, and a 6 pack intake i need all the help i can get. Keeping the cylinder psi up around 180 along with a cam near 600 lift and 255+ @.050 might do it.
How stock appearing? Exhaust manifolds? Much harder to do..I simply want to drive to the track on a hot 85/90 degree day in my stock appearing 71 demon 340 6 pack, drop the drag radial pressure a bit and click off a easy 11.50 short shifting, maybe last pass of the day shift it up around 6,500 + for a low 11 pass as they kick me out! So for guys like me with ported J's, 3500lbs race weight, and a 6 pack intake i need all the help i can get. Keeping the cylinder psi up around 180 along with a cam near 600 lift and 255+ @.050 might do it.
It has a 4,400 converter, ported 6 pack with the DC mechanical carbs,hard to do most anyway with that 6 pack, stock stroke, etc, etc. gonna take some convertor among other things, especially if it weighs that much
340’s with J heads dont just run mid 11’s falling off a log.
It has a 4,400 converter, ported 6 pack with the DC mechanical carbs, View attachment 1715869586
Actually this 6 pack feels stronger than my 750 dp on a torkerII, and strip dominator with or without a 4 hole spacer.It has a 4,400 converter, ported 6 pack with the DC mechanical carbs, View attachment 1715869586
Just get Dave Dudek to build it for you.
Dave Dudek Musclecars
It will look stock and make all the power you need. Not cheap though.
the hemi in his old black roadrunner had a 900 lift roller in it. He is very sharp, but that car running 140+ mph isnt magic, it made LOTS of power.
