"It ran when I pulled it"
Mojoe9955
NJ
Just a few things I found in a $350 318/904 combo I picked up recently off FB Marketplace.
The stuff on the blue came off the oil pick up screen, the other stuff on the
white paper came out of the block after taking out the freeze plugs. This is the worst of it I hope.
The pile out of the coolant passages is normal stuff. Foundry sand that didn't get shook out. The wires used to be long pieces to hold the cores in place.
Man you have the nylon tooth timing gear? i was replacing those in the late 80s... :thumbsup:
The date code on the block was 12/72 and came out of a 73 B Body I was pretty surprised to see that.
Was that original equipment?
The greasy young shade tree mechanic I got it from, replaced it with a 440/727 he got from his buddy. That ran too... I heard it
We all started somewhere... You work on this old stuff & your gonna get greasy... You paid $350 for a engine & trans core... You got what you paid for...
I think that was something I might have picked up from the Magnum swap community, which is how this all started. I have a 5.2 Magnum wanted to build and wanted the LA parts and the 904 for that.
