slantsixdan
How I found it (1st post) and tech details (4th) here.
What's it hit?Doesn’t fit big block, BTDT.
The blockWhat's it hit?
I believe you, but I'm having a hard time picturing it. Is it the solenoid that hits the block, or the starter frame? If it's the solenoid, I'm guessing it's a "one or the other" deal: either the Mitsubishi starter ('05-'08 Ram 5.7 Hemi) will fit and the Bosch one won't, or vice versa.The block
I don't know if it was the exact starter you linked to , but the body of my starter hit the block and cocked the starter over. Grinding the block was a quick, easy fix , plenty of meat there. A pic from the net for reference. The scooped out area on the block for starter clearance, take off a little more material.I believe you, but I'm having a hard time picturing it. Is it the solenoid that hits the block, or the starter frame? If it's the solenoid, I'm guessing it's a "one or the other" deal: either the Mitsubishi starter ('05-'08 Ram 5.7 Hemi) will fit and the Bosch one won't, or vice versa.
It’s been 5 or so years so I’m not sure. I had the standard nippon Denso mini that I use in everything so I swapped it in and sent the Hemi starter back to rock auto.I believe you, but I'm having a hard time picturing it. Is it the solenoid that hits the block, or the starter frame? If it's the solenoid, I'm guessing it's a "one or the other" deal: either the Mitsubishi starter ('05-'08 Ram 5.7 Hemi) will fit and the Bosch one won't, or vice versa.
But the "different kind of mini starter" this thread is about is not the '05-'08 Hemi/MT starter. Looking at the block pic, I can imagine where that starter would hit…and I think the Bosch one this thread is about, would not.It’s been 5 or so years so I’m not sure. I had the standard nippon Denso mini that I use in everything so I swapped it in and sent the Hemi starter back to rock auto.
You're blocked from accessing slantsix.org…? Try a different browser.Do you need to bushen that one hole?
Pretty good deal but what is the advantage over a typical gear starter for like a 96 Dakota like I’m used to buy for small block? Sorry I still cannot get info, my browser is not allowing me access due to safety concerns.
They're been giving 503 error messages lately from time to time.You're blocked from accessing slantsix.org…? Try a different browser.
Honest? A good one of those is always going to be my first choice unless I'm forced to choose otherwise. It's bigger, heavier, less powerful, and less durable…and one of the first things I learned in this world is that's what a car being cranked is supposed to sound like.Wither the highland park hummingbird.
