I have a Holley 80508-3 ([ame]http://www.holley.com/data/Products/Technical/199R9934-3.pdf[/ame]) on my 390hp 360 magnum crate engine, I want to up the jets in it a touch, because the plugs look a bit lean. The porclins white around the electrode and the groud stap is pretty light.
I have the stock 70 primary jets in it, and, i'm sure, the stock metering plate (I have no idea what this is , but i'm going by the manual in the link).
My question is do I need to up the size of this metering plate or do I just up the size of the main jets to offset a lean condition?
thanks!
thanks!
