Just blew up my rear end VIDEO
Welp. Blew up my rear end. ‍♂️♂️
I always broke them on the starting line , got to be every other week end , went to dana 60 , end of problem !
LONG TIME AGO---------------
No trans is also built. Was gone through late last year also ‍♂️
I think what he was getting at is when the rear let loose it can over run the sprag? Not sure if that’s the correct problem that happens but anyway you should take the trans apart and check the sprag.(even if you already have a bolt in sprag?) I’ll let the pros chime in.
I cant stop staring at that video clip at the bottom of your post. Is that from some movie?
