[WANTED] just need a couple big block 413 pistons
Loggato
Central Kansas
I need a couple of pistons for a 413. I really only need one, but would prefer maybe one or two more just to make sure I have enough in case something else breaks as I'm pulling this locked-up engine apart.
Standard bore, Flat tops.
would also be interested in valves. If you have a few kicking around, let me know! Thanks
If the engine is locked up, I'm betting it's probably going to have to be bored. I'd go that route & get a new set of pistons & rings, rather than rely on trying to use old possibly mismatched pistons.
it's my plan B. but It should clean up OK enough for a "budget" rebuild with standard size parts.
Pistons are hard to find for a 413, if you cannot find used, check EGGE Speed, they sell alot of pistons for older engines.
I got a set of .080 over 134 Willys flat head pistons from them, reasonable and saved an engine block.
eBay has a complete set of standard bore 413 pistons and rods it looks like probably half of them are salvageable if you want to take a look
