MOPAROFFICIAL
If it has tits, it's a liabilititty.
Some are 10 degree, that's why i ask
Looks like a thicker satellite as well. Maybe just flow test the valves at the same lift where both exposed an equal amount of under cut stemThe reduced shank on the 11/32 Edelbrock is a little taller. That would skew the results slightly.
The Hughes valve is about 0.020" thicker.Looks like a thicker satellite as well. Maybe just flow test the valves at the same lift where both exposed an equal amount of under cut stem
