danial
Active Member
69 dart ran over bolder smashed k-frame got used k-frame from68 dart rear holes don't line up how can I draw the body in about 3\4" to line up back holes?
I thought about a come-along not sure if I have the space I need to pull the frame together its so closeouch. frame shop. big tree and a come-along ...
Drilling holes in the vertical portion of the frame rails? Um, yuck.
Just take it to a frame shop. Liability and all that, plus a job done right with no alignment issues or funny business down the road.
IMO.
How in heck did you spread the frame rails at the rear? Was it being parachuted into the desert?
IMO, a frame shop is needed. Both frame rails may not need the same amount of "tweaking" (if we call 3/4" a tweak). It may all be on one side.
Good luck,
C
Don't believe there is $$ for a frame shop on this one.
It can be done. I would also line up the k and put in the 2 front bolts and tighten them holding the rear of the k to the frame with a jack. If 1 hole gets there before the other put in that bolt and tighten it too. Draw the other rail in until it lines up, put the last bolt in tighten it lower lower the jack and carry on.
got it bought come-along pulled it in just enough to start the bolt now to take back come-along.thats enough for today go check out waves.
harbor freight 17.99
all that stress for that its all up hill now.HA HA HA
