k frame repair (lower control arm shaft hole)
flathead5173
Active Member
wadsworth ohio
I have a 73 duster. The hole on the k frame for the lower control arm shaft is wallowed out. How do I go about repairing this?
It's hard for them to wallow out, but it is possible if things were left loose at some point. Post pictures of the area for a solution.
Like this?
You do what I did, all of them eventually fail, it's best to take out the k-frame and reinforce it anyway.
http://www.forabodiesonly.com/mopar/showpost.php?p=1969963421&postcount=62
But if your looking for a quick fix, weld it up, both sides, and do the steering brace like I did while your at it, it's right there.,. See where the crack was next to that first bolt on the left? I'd say this fixes the majority of the flex in the frame.
If you want to go the full way you can touch up the factory welds if you'd like, and go around the perimeter every 2", 1" beads and make that sucker stiff as a hickory bat on opening day.
If your doing that you might as well do this too:
Jim Lusk's Nice video on the fix
[ame="http://www.youtube.com/watch?v=Nwes-SP8u4w"]Control arm repair - YouTube[/ame]
Here's another version so you don't have to buy the $30 plate:
http://www.forabodiesonly.com/mopar/showthread.php?t=231939
Install some 'offset UCA bushings' while your there to get that better handling caster.
http://www.forabodiesonly.com/mopar/showthread.php?t=231627
Bushing tool, install arrows pointing paralleled to the UCA body. The correct direction, front out, rear in.
http://www.forabodiesonly.com/mopar/showthread.php?t=156654
Check out this quick tip to firm up your PS box if you have one:
http://www.moparaction.com/tech/beep/PUMP_IT_DOWN-re-v1.4.pdf
And oh, yeah, check all the bushings too. It's a great time to replace them, especially that LCA:
http://www.moparmusclemagazine.com/tipstricks/155_0306_control_arms/viewall.html
K.. being cheap.. and also i like to try to fix **** instead of buying new :) If he can get the tubes out without too much pain.. use the old LCA pins and hammer the tubes back into shape on them and install in the k-frame with washers to reinforce if needed... still doable :)
Yes post a pic or two so the membership can see what is the issue is. Might be easier and better in the long run to procure another K frame ??
Wishing you good luck
