I am in the process of rebuilding a set of K/H Brakes. I have two different hubs no real issues as far as I'm concerned but when I ordered bearing and races. I removed the races from both hubs and when I installed the new races on the one hub everything fit correctly but on the other hub the small outer race when it is installed the race spins around and is loose. So I guess I need to ask if anyone knows if these hubs have different bearings and races, and or is the hub I have wore out? The hub in question has the following numbers marked on it 59155.
The larger races fit perfect with no issues.
Thanks for any and all help.
