K member identification
Cazbah362
Nevada
OK - standard question, I have a K member with number 049M502, which is on the mount/oil pan side. I would suspect it is a 70 E Body, but would like more information if possible.
Abodie, read that, gives year and if its a /6 to Hemi, have that generally figured that out, why I think its an 70 E Body, however, I figured with the numbers, sway bar location, etc someone may know a little more information.
Maybe try an e-body website. There may not be the people on this a body website that can give you a 100% accurate answer. If there is I am sure more pictures will help.
Craig - Thanks for being helpful, Yes agree they do look they same. Do you have any numbers stamped in yours?
