[WANTED] Kelsey hayes rotor
Rock auto
Use the part number to find local.
Centric Parts 121.63005 Centric C-Tek Standard Brake Rotors | Summit Racing
Did look and cant find there it keep saying not found on any clicks on those.
1970 plymouth service manual about 1/2 way down the page.
any of the manuals from 65~72 will have the service information on the KH 4 pots, but best to have the year you're working on, or one that's close.
Even though the Kelsey-Hayes rotor and hub were a two piece assembly, they were only sold from Mopar as the entire assembly. It was the aftermarket that offered rotors without the hub, which requires separating and re-assembling hub and rotor.
Since they weren't sold as separate parts, service manuals don't cover the procedure of separation and re-assemby. At least some don't.
You can press or hammer out the studs, and press or hammer them back in with the new rotor. Just be sure to check if the rotors and studs are swaged to cut them loose. Using new studs wouldn't be a bad idea, either.
