orangecrush
- Joined
- Aug 8, 2008
- Messages
- 147
- Reaction score
- 0
My brain can't get a handle around kickdown adjustment. I have a Holley Avenger and an AirGap - when I open the throttle (pedal to floor) the kickdown slotted rod is pulled forward (if play is out), towards the front of the car, which is pulling trans kickdown lever forward as well. from what I'm reading, this is bass-ackwards ? I need a freakin' video as I've got no other cars to reference but a slant - . I understand the kickdown should move immediately as the throttle begins to move (and it should move the lever to the back of the trans, not foward) - this can't happen with my setup as the spring has the lever in a forward position, and pressing throttle tries to pull forward more, something ain't right ? . This can't be that tough!
